Hi folks, I know this topic has been beat to death but I have a question I'm hoping someone can help me with. This is on my 1946 Farmall H
with a 6V + ground system. A year ago I rebuilt the engine and put a whole new wire harness, new 6V battery, new 6V regulator, and I had a
local shop rebuild the generator. When I first got the system up and running it ran and charged great, charged the battery, + charge
showing on the ammeter, lights nice and bright. After about a month or so I noticed my headlights getting dim and the ammeter no longer
showing a charge, but now a discharge. Basically it stopped charging. I started going thru the troubleshooting guide posted on here
(link below). The first test is to remove the genny main and field leads and start tractor and run up to 3000 rpm genny speed (I assume is
full throttle). According to this guide I should get 2-4V between Main and ground. What I am getting is increasing volts with engine
speed...starting around 0.5V and topping out at 1.5V at full speed. If I read th eguide right that means I have "c). Voltmeter reading
rises with engine speed = short circuit between Main (or D) and Field (or F) terminals. Field coils defective."
I want to just verify if that is the correct conclusion. When I took the genny apart I tested the field and armature and seemed to pass
every test. Let me know what you think.
http://www.yesterdaystractors.com/cgi-bin/viewit.cgi?bd=farmall&th=811423
