Hello all,
I'd like to put a Cat 1 3-point on our 350 Utility. It has the fast hitch on it, so this should be a relatively easy addition. The problem is, I don't yet have any Cat 1 PTO driven equipment (planning to rent a 3pt tiller in a week or two). I want to make sure there's a proper distance for the PTO shaft. The width, lowest height, max height and min-max lift range dimensions I've been able to find, but I'm not sure what sort of distance from the pins to the PTO I need to build in. For example, when the implement pins are level with the PTO shaft, what is the distance from the center of the pins to say the lock-notch on the PTO shaft? Or, when the PTO is level, what is the distance from the PTO lock notch to the pins and the PTO/Pins vertical offset? Or if someone happens to have a set of Cat 1 fast hitch lowers, the dimensions of those?
Thanks for any help you guys can provide. Since one should be able to adapt cat 1 implement onto cat 2 with just bushings, I've been tempted to just measure the distance on one of our Cat 2 tractors and duplicate that if I can't get a measurement from a cat 1 setup. I'm just hoping to build it to match cat 1 standards from the start to minimize future "quirks".
Chris
Chris
