My 766 was badly in need of a new engine clutch, which I have successfully installed. It also had a growing difficult gear shifting problem. After installing the new clutch I've adjusted the clutch linkage (hydraulic assist), the transmission brake and the dump valve according to the shop manual. Clutch, of course, performs well but the difficult shifting remains. Now, this is a 40-year-old tractor, so could it be possible that adjustments compensating for 40 years of wear need to be made different from the manual specifications? Could the dump valve itself be failing? Or, could the PSI sensing unit be faulty? Thanks in advance for any suggestions!
