Mark Poss
If using round up ready pro concentrate to spray corn how much concentrate should be mixed with water? Thanks for any help, Mark.
Mark! Read the label! We have gone over this before.It is oz/pts/quarts per acre,not per gallon of water.EVERY sprayer is different,so it is product per acre.every time.Except for the little hand sprayer you carry to spray around the farmstead. Read the label !!
mark, like delta red said, its amt of product per acre, not oz per gallon. here is a link to monsantos application rate chart and how to figure mixing.
poke here
The only time you mix any herbicide on an "ounce per gallon" basis is with a spot sprayer for non-field use. Any time you are spraying an acreage you need to use "ounce per acre" - otherwise you have no idea how much chemical you're actually applying. You say you're going with 2 oz per gallon but is your sprayer applying 5 or 25 gallons of solution per acre at your selected travel speed? It makes a huge difference in how much actual chemical you're putting down. It is irresponsible for anyone to spray any chemicals without knowing how much is being applied per acre.
