I finally got the toolbox removed from the tractor in taking off the 2 point hitch to swap it to the Super C. All of the toolbox bolts had to be torched. Upon removing the hard hydraulic lines, hydraulic block, and soft hydraulic lines I decided to clean things up and blow air through all of those passages to make sure they were clear. Well I removed the 2 large things on the sides of the Hydraulic block and then the rain hit and I had to run inside the shop. Now I'm trying to put back together and I can't remember which side they came out of. One is longer than the other so I know it matters. I Can't find this part in the online parts book.
