Hi guys. I've browsed the forum and tried a few suggestions but am still having trouble. I have a 340 utility with the hydraulic pump that runs off the timing gear. I've lost all hydraulics. No loader lift, bucket tilt and fast hitch lift. I've opened where the hydraulic lines mount to the pump, on an incline. I had fluid coming out the lower line. I started to open the cover for the hydraulic filter and had fluid coming out there. I changed the fluid 8 months ago and the hydraulics worked fine until 4 months or so ago. The tractor doesn't get much use. Before things quit completely, the loader intermittently worked a few times. Any ideas? Thanks in advance.
