farmall super a
gidtex
How does the distributor shaft get grease,i
pump grease in side hole and block little
hole back side but no grease came thru
bushing,it will come out little hole . Seen
like someone replace bushing in past
because the shaft fit snug in bushing.
I have 4 of these little tractors everyone of them have a straight edge screwdriver plugs in them. I pull them and drop a few drops of oil in them. I think somebody has put those grease fittings in there
You are su[pposed to remove the slot head screw and install a zerk one shot of grease then remove the zerk and replace the slott head screws that way it will not be overgreased.
