560d injector
560farmer
When I try to start it then begins to leak diesel out of injection lines at pump is my pump bad the tractor won't start also thanks
Should be no leaks at the pump if all the banjo bolts are tight. There are two gaskets on each banjo, one on each side. If they leak with bolts tight the gaskets may need replaced. Do you get any exhaust smoke when trying to start it? If so then you are getting fuel In the chambers, but not burning it. Could also be bad glow plugs or connections, or plugs not held on long enough.
(quoted from post at 08:59:18 04/29/16) Should be no leaks at the pump if all the banjo bolts are tight. There are two gaskets on each banjo, one on each side. If they leak with bolts tight the gaskets may need replaced. Do you get any exhaust smoke when trying to start it? If so then you are getting fuel In the chambers, but not burning it. Could also be bad glow plugs or connections, or plugs not held on long enough.
t does smoke white
if its smoking white the glow plugs are not working. the leak will not make it not start.
(quoted from post at 19:23:10 04/29/16) if its smoking white the glow plugs are not working. the leak will not make it not start.
okay thinks my gauges say they work but that doesn't mean anything should I just go ahead a pick some up?
