C32 Loader on fast hitch Super C
I have access to a C32 IH loader and understand perfectly how to plumb it with a non fast hitch tractor, the parts are available on ebay but how do you plumb one on a fast hitch equipped tractor. Also does anyone have a copy of the parts and operators manual for the C32 I need the publication number off of them so I can get them at work.
How about photos of them on tractors??
Thanks Rex
I have a lock out valve to switch the fast hitch to the loader, and two shutoff valves on the loader to hold it up while using the hitch(one on each cylinder) It was installed by the dealer when new in 1953.
I may be mistaken but I think you can install the hydraulic bypass block in behind the fast hitch valve, add an aftermarket one-way spool valve for the loader, and have all functions available at once.
Worst case you could get a standard hydraulic manifold, install the bypass block, and a dual-spool aftermarket valve with a one-way for the loader and a two-way for the hitch.
(quoted from post at 07:00:25 04/29/16) I may be mistaken but I think you can install the hydraulic bypass block in behind the fast hitch valve, add an aftermarket one-way spool valve for the loader, and have all functions available at once.
I'm not sure about installing a bypass block behind the existing valve. You may block flow from the existing valve to the pressure relief valve. If so, allowing the Fast Hitch to hit the end of its travel may dead-head the pump. That would potentially be an expensive mistake. It may depend on the design of the bypass block.
