Hello guys,
Im a lurker and been seraching around for tips on here. I have pulled a Super C out of the shed after sitting for 7 years. It was my granddads he bought when he started farming in the late fifties, after he retired farming he kept and used it to grind feed for his hogs. After he died my dad started a slow restore on it, but that stopped after he passed suddenly. So I pulled her out, swapped the coil, rebuilt the carb and we're off..... So I have been searching through the hydraulic troubleshooting. I had to replace the rear lift cylinder on my Super C as it was pouring fluid, replaced the lines as well. I filled up the reservoir, bled the air and went to work. Then very quickly it crapped out again. I put two gallons of hydraulic fluid in it. I saw the leak across the front tire, so I cracked the petcock and oil was pouring out. So after looking on the forums I figured the drive shaft seal for the pump had gone bad as it sounds exactly what have happened. I pulled the hydraulic pump today and the seal "looks" good. Its a "newer" pump that my dad had put on before he passed. I'm kinda lost here on it. Is it the seal, despite it looks good? I've learned there are two different pumps for those C's??? so with that the pump I have has the pump "seal" not o-ring. So thanks in advance for the help...
Gus
Gus
