Rebuilding Remote Hyd. Valve on Farmall 200
RTR
Would anyone happen to know what parts would be needed in rebuilding a remote hydraulic valve on a Farmall 200? Just acquired one on a parts tractor and going to clean it up and install that and the 2 point hitch on a Farmall Super C. I wanted to clean up the valve and rebuild it before installing so I knew everything was ready to go!
Just curious if anyone has ever done this before and had the parts list and part numbers (crossover if possible due to Case/IH prices & distance to dealer)
Here is a picture from eBay showing which part I'm talking about.
Thanks,
Chase
From the Case/IH parts diagram the only o-rings I've found are the ones at both ends of the hydraulic manifold (lines).....2 on each end.
The hyd. valve itself only looks like it has (1) oil seal, (1) rubber boot, and (1) bottom cap gasket as serviceable/replaceable parts (unless somthing is broken of course).
Am I correct with this?
Has a copper washer on bottom plug, One O ring I think on the spool, 2 o rings on the pipe flange, gasket on the back and the boot on top.
(quoted from post at 23:18:20 04/28/16) Has a copper washer on bottom plug, One O ring I think on the spool, 2 o rings on the pipe flange, gasket on the back and the boot on top.
Yes...boot will have to come from aftermarket source.
Why aren't the o-rings shown on the parts breakdown? Do you know the sizes?
Gasket on the back meaning from the lines to the TC block?
What about the oil seal that is mentioned?
I can't get the IH part number to cross reference.
(quoted from post at 23:29:01 04/28/16)
Anyone ever rebuilt one before and know where I can source the parts locally? I have o-rings in the shop but need to know sizes. I can also get a seal at the local parts store too if I knew a part no.
