Heavy attachment for 3 PH want tires under?
Hi, I have a heavy attachment coming about 900 LBS. Would like to know if anyone has seen or made anything to help support the three point hitch? Thank you, any help in this matter much appreciated.
Bob
What is the tractor? what is the implement?What are you trying to do with it? 900 really isn't that heavy.Unless you are useing
an 8N ford. I often used just a chain. loop around a solid high point,then loop around the 3 point arms,make a triangle.If you
want to get fancy.a couple strap irons from toplink to 3 point pins works.
They make straps just for that but you need open ended center link pins to use them as transport hold bars
(quoted from post at 15:22:18 04/27/16) What is the tractor? what is the implement?What are you trying to do with it? 900 really isn't that heavy.Unless you are useing
Sorry, forgot to say Farmall C with hydraulics. Under stand 500-600 LBS is limit? I have a 3 point hitch after market. Believe it is called Work Saver?
I have a Farmall C with hydraulics, and an after market 3 point hitch Work saver I believe? Want to lift a Wood Max WM-8 wood chipper.
Hi Bob, after looking at the company web site and the information on the model you are asking about I would think you could adapt some wheel under the chipper, but I think I would have gone with the next size smaller unit the TM-86 it only requires 15 hp giving you hp to spare and it weigh in at about 600 lb and your tractor could handle that.
GB in MN
(quoted from post at 02:19:25 04/28/16) Hi Bob, after looking at the company web site and the information on the model you are asking about I would think you could adapt some wheel under the chipper, but I think I would have gone with the next size smaller unit the TM-86 it only requires 15 hp giving you hp to spare and it weigh in at about 600 lb and your tractor could handle that.
GB in MN
I wanted something a bit bigger and looked at them all. Wanting the hydraulic feed and the ease of the one chosen. Will to implement if need be. Thank you for your suggestion.
OK, I will go that route if I have to. That means I will have to sell my 1948 Farmall C that I have restored, but you have to do what you have to do. Thank you.
