I'm getting back to work on a very leaky Farmall 706.
I have a VERY serious leak in one of the tubes to the steering mechanism, at the union just behind the radiator. Tightening doesn't help, so I guess I'll have to replace that tube. The front end of the tube is under the radiator, at the bolster. In addition, even in warmer weather, the steering squeals and has to be primed by turning right. Added to that, I found small pieces of rubber? in one of the auxiliary hydraulic quick connects. My guess is that pieces came off of the ram seals on the front loader bucket and got in the system.
So, I'm thinking that I should inspect various pieces, and replace any o-rings, etc.
Here are the questions for now:
1. I have to remove the radiator to get at the front of the steering lines on top of the bolster. Can I remove the bolster without blocking up the front of the tractor? I have the manuals, but they seem to be for a narrow front wheel variation instead of the wide wheel type that I have. (It seems scary that one bolt in the front axle holds this whole thing up!!!)
2. When I get to the hydraulic pump and the MCV, do I have to drain the 15 or so gallons of hytran first?
The top photo is the steering bolster from the right side. The second picture is the steering bolster from the left; the steering hydraulic lines are at the top right, and the engine pulley is at the top left.
Thanks for any advice,
Jim
Jim
