Dave Innerebner
I got a new starter for my H. First install the starter would not stop turning. could hear it rattle as I drove. Backed it off and it seemed to disengage. Ran it a few more times and then suddenly it would not engage to start. The positive lead was getting hot. Took starter to get checked and it was fine (so he says) I heard him test it, seemed to work. I put it back on and shimmed it with washers. Starter engaged again but seems to not let go of fly wheel. Tractor runs while I have the starter turning and dies as I release the starter switch, which is getting hot in the mean time. If I hold in the starter switch the tractor keeps running. As I release the switch the rpms drop, tractor dies and I can hear the starter turning with the engine. Switch is getting hot. More shims? seems like I need to back off the starter more but I do not like the pressure put on the start casing by just the two bolts...
any thoughts?
any thoughts?
