I took all three spool valves off my 560 to rebuild them - one teledepth, and the other two normal ones.
Of the two "normal" valves, one of has ports on the bottom that are closed with threaded plugs. The other has no ports on the bottom.
Now I can't remember which one goes where. Obviousy the teledepth on goes on the let hand side but not sure about the other two.
I'm assuming it doesn't really matter...
But - that's my question - does it? Is the one with the plugged ports supposed to go in the middle or the outside?
Thanks
Thanks
