Farmall A cam end play
kopeck
Just popped in my cam and the end play is pretty excessive, like .030, spec calls for .005 - .010 but they don't indicate how I'm suppose to account for the extra play?
K
So where is it going to go the holder will not let it go forward towards the radiator. It cant possibly hurt anything having that much end play. Put it together and run the snot out of it.
(quoted from post at 05:41:52 04/25/16) So where is it going to go the holder will not let it go forward towards the radiator. It cant possibly hurt anything having that much end play. Put it together and run the snot out of it.
I wondered if it would play with the timing of things but I guess the gears probably stay in one position once running. Visually I can't see where anything wore to create the end play, I wonder if more are like this then not. Funny they give you a spec but no way to adjust...
I also found the endplay on the crank to be slight like tight. I'm seeing .0035 and the books calls for at least .004. I doubt .0005 is going to make or break things either.
Thanks,
K
