I have a Farmall H that is plumed to a loader with one way cylinders using to front port on the left and right and a one way using the back port on left for a hose out back for equipment. . Today I tried to plum my M run a two way cylinder as a one way by venting one port in the cylinder. I am using the one port on the right side of my M and it acts like it is blocked. It worked a little the first time I moved the lever and then stopped and not won't move the cylinder and yet there seems to be pressure on the hose going to the cylinder. Never tried to use the hyd on this M until today, but something is not right. Should I use the left port for one way if that is all I am using the Hyd for? The cyliner is free and when the hyd is in neutral position I can push the cylinder closed. So, not the cylinder or hyd connectors.
