fast hitch 211 mower
dewy
hit something sheared the shear pin...went to check blades and noticed i broke the tip off one of the blades...looks like it lost about a inch and a half..... my question is ...are those blades still available and where would i find one....as always thanks in advance.......dewy
If you are talking about a knife section on the sickle bar, the long removable item with lots of identical individual pieces secured with two rivets that moves back and forth and driven by a wooden pitman or belt, they should be available at any good Farm and Home Supply almost anywhere. If something else more definition is needed, Hal.
