MTA-D,kentucky
New User
We are working on a M that has the guts of an M+W hand clutch. Someone welded up the discs to get it to pull and did away with all the covering and handle. Any way we acquired almost nearly everything to put the hand clutch back on it. My question is this. Is the adapter plate that bolts on the tractor necessary or even called for on a straight m, or is this made for a Super M? I am in question over this because the M+W specs don't show this plate for an M but do for a Super. Also the housing cover seems to match perfectly the bolt pattern around the brake drum and chassis. The gentleman that the kit was bought from wasn't real familiar with it and didn't know what the differences for a M+w to a regular M and a Super. Thank You for any info on this subject.
