MaverickM23
I recently got a 5x16 IH 700 plow. Had it in the shop and set everything up according to the manual. The steering pipe was all messed up and the front hitch wasn't set right it does have a sidehill hitch attachment to slide the hitch right or left and it is an in the furrow hitch. Went out and used it with our 1456 and it worked well except when I go to turn left the plow wants to roll over and acts like its going to flip. I do have the proper IH sway linkages and they are in the locked position. I have the three point hitch arms on the plow mounted one lower than the other as the manual suggests, could that be why it wants to flip when I turn? The book also talks about a vertical limiter but I do not have that could that be an issue? Thanks
