smoke coming out of the tube
newhaven
After replacing freeze plug on super c back together and run Great I noticed a little smoke coming from the bolt holes in the tube behind bell housing ???
One issue might be the heating and evaporation of coolant from the repair. If it is real partical based smoke, it will need further assessment. Jim
What kind of sealer did you use on the new plug? Is it still leaking steamy coolent?
OR you have a clutch issue causing burning somthing may be trough out bearing? OR are you burning oil or greese off the clutch disc?
(quoted from post at 09:47:21 04/18/16) What kind of sealer did you use on the new plug? Is it still leaking steamy coolent?
no leaks from freeze plug I did grease the throw out bearing and cleaned the bell housing full of mice nests
