H hyd. Lever
DTK
It seems as if neutral on belly pump lever has changed. I have to push lever all the way forward to lower and when I raise and let up on the lever it will slide back forward but it keeps on lifting unless I move it more forward than I used to . Any thoughts ? Thanks DTK.
check the mount bolts under the tractor, and check the bolt that holds the lever on the rt side of the housing where the rod is attached. the steering post or light bar could also be loose. Jim
I agree what Jim says. I have "restored" a SH and SM -- they had to be adjusted when I replaced them.
