Farmall Super A Wheel Problem
Spudm
The rear wheel dish holes are worn out where the bolts go through, and are now oblong. Question is: Can a welding shop repair this, or would it be best to replace the dish & wheel with new? Cannot drive it because the wheel may come loose from the dish.
A good welder could probably do it--but I would rather have another wheel. I assume you mean the left wheel, the right one is cast. If your tractor doesn't have that one, get one for safety. If the cast one is worn the tractor has been treated by someone with no sense.
Correct, it's the lighter left side of the tractor. I am going to talk with the welding shop first and see what they have to say.
