Boiling batteries
DTK
On my 656 diesel the batteries boil out the acid at times. Can I adjust the reg. to not do this? It has an alt. With separate reg. It came that way from factory. Thanks DTK
Replace the regulator! Also make sure the reg has a SOLID ground to the engine. A dedicated ground wire from the reg base to the ground stud on the alternator is recommended.
