Hi,
I have a Super C that is missing the pin that connects the steering linkage to the gear assembly that turns the front wheels.
The steering wheel connects to a shaft, then several u-joints and finally at the front of the tractor to the gear assembly.
I'm currently using a universal clevis pin with cotter pin to join the parts together. During mowing, the pin usually breaks and I've got to reassemble things in the field.
I think that a roll pin was used originally.
Does anyone know if this is true and if so what diameter and length of roll pin is needed.
Also, any installation tips?
There isn't a lot of room there.
Thanks,
Mike
Thanks,
Mike
