Farmall M pinion bearing cage
Hi, my Dad and are working on a '39 M with a broken bearing cage. All of the replacement pieces I find look different on the brake side/outer flange. This is kind of skeleton looking/ribbed on the outside where all the ones I can find are basically solid on the outside.
Will a cage from a later tractor bolt right up? I understand the disc brake (Super) tractor is a completely different piece. Thanks in advance for any help.
The best I can think related to your situation is that the device you have is actually a early production component. 39 through mid 1950 were different in many ways. I would obtain a flat faced cage and measure it in comparison to the one you have. im
New posters need permission to post (this keeps nasty intrusive images) ask Kim in site Feedback Form. Left and down. Jim
