scotthorn727
New User
The 1976 IH574 with a D239 engine stopped running. The previous owner suggested getting the injection pump rebuilt when I bought the tractor. I scribed marks on the injection pump, removed it, and took it in to a diesel shop to have it rebuilt. The diesel shop owner told me to forget the scribe marks and bring the number one cylinder to 14 degrees BTDC and line up the mark in the ip window. The problem I have is that there is no marks on the pulley to tell me where 14 degrees btdc. So, what I did was line up the 1 mark on the injection pump gear at 9 o'clock, #4 mark is at about 7 o'clock. Then I lined up the mark on the ip window. I had to remove the 3 screws in order to do this. I also removed the #1 injector and confirmed the piston was approaching TDC. It wont start. I bled all the air out and confirmed diesel to the injectors. How do I know if I am on compression stroke when I see the gears on the timing pump go from 1 to 4 when turning the engine over by hand? Any ideas how far off I am off to time this motor?
Your help is most appreciated.
