Ken Christopherson
Well, after taking a drive to the salvage yard today to check out the tractor (since I had only seen it in pictures), I decided not to go with the 1942 Farmall M. By the time I switched out the rear cutoffs for cast centers with rims and (used) tires - one of the cutoff rims was rotted and tires were surprisingly still holding air, I would have been into the tractor for $1,000. I found the tractor was also missing the generator, the hood had a large gash, and the grill was pretty banged up. I started looking around at other tractors on the lot to see what else they had for M's. Found a 1947 M that was 100% complete (even has the steering shaft toolbox), motor loose, and had a Paulsen loader assembly mounted. Started asking some questions about it and discussed the possibility of taking that one home instead. Negotiated some (not taking the loader since I've already got one)... And ended up paying for it in full. I'll be headed up next Monday to load it and bring it back home.
Bummed that I'm not saving a war-time M... But I'm saving one nonetheless. Tin is good and straight (except for a couple of minor holes in the nose of the grille), tractor is very complete, and it has nice tires on the front and rear. Enjoy the photos.
