Front Wheels for W4
I have a W4 with solid cast iron front wheels. I would like to find out what the part numbers are for the lighter weight front hubs with stamped steel rims. Barring the part numbers, what hubs/wheels from other IH tractors might work. Can anyone help?
for the front wheel with skid ring, the part number is 6694 dcya. for the tire/rim combo, there is a serial number break, 501 to 4247, then 4248 and up. 6762dfxa shows the front wheel complete for the w-4 from 501 up. 9214 daxa is the front wheel complete rim integral part of wheel for the o-4
heres the list on the rims
45406d for 4.00 e x 16 dc for 5.50 x 16 or 6.00 tire, for the w-4 order 354223 r1
351509 r92 for 4.00 e x 16 dc for 6.00 x 16 or 5.50 x 16 tire used with wheel 6762 dfx (w-4) serial 17402 up
354223 r1 4.25 ka x 16 dc for 5.50 x 16 or 6.00 x 16 tire .....6.50 x 16 on o-4 only will work for 45406d w-4 501-17401
354244 r91 4.25 ka x 16 dc for 5.50 x 16 or 6.00 x 16 tire 6.50 x 16 on o-4 and os-4 only, will work for 351509 r 92 w-4 17402 up
see, easy as pie!!
6762-D? wheel for plain rims with no loops. Wheel 8274-D? for 3 loop mount rims. Suffix letters will get higher on later wheels. Wheels found on H,SH,300 and 350 have one of the numbers. Late H up can have wheels 8274DB with rim bolt points thicker in wheels.
Forgot to say IH wide fronts with tie rods out front on H and M also use the wheels. clamp type wheels found more on early tractors, and 3 loop more on later ones.
