Hello I am a new member to this site,
I am a senior in high school and my FFA Chapter acquired a 1944 Farmall H 4 years ago and the previous engine class took the tractor apart. Currently the motor block is off the tractor. I am curious on the dowel pins that help line the motor up to the clutch housing. Does the threaded or non threaded end of pin go in the clutch housing? Also the clutch disc is getting replacing and not sure which end of the disc goes towards the flywheel and which goes toward the tractor? Does the protruding (longer side) go towards the motor or vice versa?
Any input would be greatly appreciated.
Thanks Tanner
Thanks Tanner
