I went through the generator on my 504 and everything seemed fine. The amp light went off while running. Today I went to start the tractor and nothing. No lights on the dash. Hooked the battery charger up and the generator started humming like it was wanting to turn. I unhooked the arm wire from the generator and tried the charger again. This time the voltage regulator was humming. I removed the regulator and got the tractor started. I took the regulator apart expecting to find something welded together and shot but found nothing. The points above the Batt terminal were open and the other two were closed. Nothing looked burned and the points moved easily. Where should I go from here? How can I test the voltage regulator on the bench? I am thinking of doing the single wire alternator but would like to know what is wrong for future reference. Any help is greatly appreciated.
