Farmall SM parts needed
PretendFarmer
My 1953 Super M is going to be primarily used at tractor pulls. With that said, I want to take the live hydraulics off. It also has the Char-Lynn power steering and I want to take that off as well.
From what I know, I need to acquire a live hydraulic delete housing to properly mount my distributor. Does anyone have one I can buy?
2nd, the Char lynn. It looks like when these were installed at the dealer(or otherwise), they had to chop a section out of the shaft to mount this. So I will need a shaft to put in its place. I am planning on putting this Char-Lynn torque motor on my H because that's where my loader is. Will the shaft from the H go on the SM and vise versa?
Thanks.
Also, I am not getting rid of the hydraulics. Only storing them for possible use in the future should this tractor return to farm duty.
Look for a ignition drive housing used from part of 50 model M on up through 450 if not equipped with a engine driven pump. Will have number 35495? R1 on it. Be real rare to find one from a SMTA through 450 though. Can't remember the last number now maybe 354951 or 354952. Ones with a different bolt pattern have 4 numbers and D? suffix. Steering worm shaft from M and SM gas. H and M worm shafts don't interchange.
This what you're looking for? 354951R1 In N Illinois, heavier than it looks, shop around, if you can't find any thing closer I guess I can spare this one.
