fast hitch on 966
i have a fast hitch on my 966 that i want to convert to 3 point hitch. i went online on caseih and found the ends and ordered them. to my stupid suprise they dont work. not long enough. is there another way to convert to 3 point? everything else i have is three point.
To make the switch from fast hitch to three point , YA need EVERYTHING . You remove the fast hitch bundle from under the tractor and unhook the linkage to the lower draft control rock shaft and where they hooked i you put the lower three point arms . YOU may be able to use the leveling boxes on the three point and maybe not . SOOoooooooooo if you want three point your going to have to rob it from a three point equiped tractor. Bone yard hopping time.
Yep,My brother bought one out of Minnesota this past fall.When I was a kid,an older neighbor 'updated' a 560 with a 'Black Stripe' 966 with a fast hitch. It was the 'talk of the town'!
Go to a salvage yard and buy the complete 3point/related parts from any of a 706,806,756,856,966.Probably cost $1000,but then you will have a 'true' 3point.Dont forget to change the arms on the rockshaft,and readjust the draft sencer when the top link plate is off.
Not long enough? Something is not right. Those things are about 2' long. A prong with a ball on the end,right?Maybe you should post a pic.
