stuck part on SC fase hitch
bass
Ok y'all here's the problem: the linkage from the rock shaft arm to the front of the fast hitch is rusted stuck. I've got pent. oil soaking the joint. I need to slide the linkage together so i can pin it. I need to do this so I can mount my rear cult. gang.
Question? will it hurt the linkage if i put a little heat on it so I can free it up?
Thanks
Bass
53superC
should be fine, just don't get it cherry red. A dull red should be more than hot enough to draw that oil into it
