Hendrik
I do remember the issue you had. Glad you got it done.
By the way, the front wheels of the Super A are loaded equally because the pivot pin is in the center of the front axle assembly. (Unless the front axle extensions are mounted asymmetrically.)
The offset character of the tractor is "felt" by the rear wheels only and that is why the Super A has a heavy cast wheel center on the right hand side. An obese driver helps too LOL
