A-151 disc plow
I have an A-151 two disc plow that came with my "A" Farmall that I need some infor/help on hooking it up, it's an early version with hand lift. I have most of it, I think, tail wheel rod that goes to right front wheel, lift arms and lever and plow itself. Not sure where everything goes with the lifting mechanism and how it attaches to tractor. Any diagrams or pics would be appreciated, it is not for a tractor with hydraulic lift.
(quoted from post at 20:15:46 01/25/16) I have an A-151 two disc plow that came with my "A" Farmall that I need some infor/help on hooking it up, it's an early version with hand lift. I have most of it, I think, tail wheel rod that goes to right front wheel, lift arms and lever and plow itself. Not sure where everything goes with the lifting mechanism and how it attaches to tractor. Any diagrams or pics would be appreciated, it is not for a tractor with hydraulic lift.
I might be able to help my uncle had an A with the same plow you got. I learned how to plow with this set up. I'm located just south on Henderson.
dad and i had almost the same set up on our 140. there was not much difference between the two plows where are you located. call me at: 903 98 2244
bass
Bass, you phone number did not come out complete, give me a call at 903-456-1851. I'm in Greenville, not too far and will be down your way for the show and pull down there later on.
