Sonny in Mn
I split the tractor on Thursday & found the main clutch gone & fairly oily. The flywheel needs resurfacing & I talked to the local clutch rebuilder & he said he has dealt with a lot of shouldered tractor flywheels & can fix me up. I really can't tell if the oil is from the engine rear main or the T/A so I will do a rear main seal also. Friday I removed the T/A, I haven't got it apart yet but I see some indications of high temperature around the tab slots in the drum. I think a saw a clutch disc & seal set on this website, does anyone have experience with these parts, good or bad? This is the first time I have worked on a hydraulic T/A so I would be grateful for any pointers or advice. Thanks.
Sonny
Sonny
