F12 Tractor Value
I have a complete F12 tractor that hasn't ran in over 25 years in the back of my shed. It has been inside its whole life. My uncles got it many years ago. It has a mounted sickle bar mower, rubber tires.
What is it worth as it sits in the shed?
Joe
Joe, it is a little hard to say without seeing some pictures. However, I will give you my ballpark "range" opinion.
If the tractor is complete, and relatively good condition (dirt doesn't count in the "good" comment), AND the sickle bar is in working order, it is probably a $900-$1200 setup here in western Pa.
If it were running, I would say $1000 - $1400, again depending upon condition. Surface rust doesn't mean much, good or bad. Original decals in place, a definite plus. If it has rusted through spots in the tin work/rims, or cracked block, those are definite minuses.
If you could provide a couple of pictures showing overall, engine area, sickle bar, and tires/rims, we could absolutely give you a better price idea.
