Next project
Gleanerk2
My next project! Hopefully soon! 656 hasnt ran in ten years does turn over!
Always wanted to try one, wanted to compare it to my 560. I think I would like the placement of the hydraulics levers better. And more room on the platform.
My favorite larger Farmall - you will really like the spaciousness of the operator's platform as you have to work really hard to find something to bang your leg or knee on. One thing to remember when changing gears always go to the horizontal neutral position and move the lever fully side to side before going to the new gear selection either up or down or forward to reverse or vice versa. That side to side movement will realign the shift rails into the proper position for changing gears as wear over the years causes shifting problems if going directly from one gear position to another. Got this tip from a long time IH mechanic to prevent getting the transmission stuck in two gears together, Hal.
