Hi
I have a 1066 IHC tractor with manual transmission. When I moved the range lever from forward gear to get into reverse, something happened so that I can't get anything but a forward speed in low range.
If I do place the gear selector lever in neutral and the range lever in reverse, then shift into any gear, the engine dies. Otherwise I do have forward motion in low range, any gear.
Is this a linkage issue and if so, where do I look to find the fault?
I've tried finding something about this in past forums but there are so many to look at. I'm thinking this must have happened to at least a few IHC owners over the years.
Thanks for any help.
