loader for a 1066
Lots. Basicly every Manufacturer makes mounts to fit their loader to your 1066.The key is to make sure the mounting brackets fit a 1066.An IH loader is more likely to have mounts to fit 1066.
The Du-al 3000 or 3100 is a light weight durable loader that is quick attach. The 66 and 86 mounts are the same. 3000 is a little older with 7' bucket, 3100 is a little newer with 8' bucket and newer style cylinders. They made them for about 25 years so there are a lot around the Dakotas and Minnnesota.
Allied made the loader on mine. I like it a lot. The quick attach really is a quick attach and you don't end up pushing anything across the yard trying to line it up. It has "made in Canada" painted on everything, but I'm not sure what kind of dealer network they have. My tractor came out of Oklahoma.
I have the IH 2350 loader on my 1066. I added a joystick and its a great setup. IH also makes a 2400 high lift loader that bolts on to a 1066.
If you want an IH loader, an IH 2350 should fit on there as well as the others mentioned. You should be able to look on the CIH website and get the part numbers of the brackets you would need.
Bought a new Buhler loader about 6 years ago for my Allis 8030. I know they make them for other makes. It is a heavy built one, made in Canada, but the bucket was shipped separate and was made in the USA.
