Hello guys...all of my experience thus far has been 1955 and prior: C, H, M...but I just found a 504
gas that is mechanically solid as a rock; recent engine and TA rebuild but need rubber and
cosmetics. It is a drawbar tractor with dual remotes, question is...if I want to add a fast hitch is it
just a matter of finding the parts and adding on? Or are the housings going to have to be
swapped?
Also will I need any extra hydraulic valving to use the remotes I will not be using for the hitch?
Thanks, Pete
swapped?
Thanks, Pete
