The series used the big spring for a auto reset trip mechanism. It works (I have one on a 3 bottom 14") but all three trip at the same time. If the plow is well planted in the ground, it will stop the tractor in 1/2 inch. Jim
And it hurts when you hit the steering wheel too! Even in first gear plowing you will not be able to hold yourself off the steering wheel if the plow stops the tractor dead. Then it will start to spin itself down if in low gear and finding the clutch with the tractor rocking from side to side can be a problem.
