504 fast hitch info
Pete76NY
Hello guys...all of my experience thus far has been 1955 and prior: C, H, M...but I just found a 504
gas that is mechanically solid as a rock; recent engine and TA rebuild but need rubber and
cosmetics. It is a drawbar tractor with dual remotes, question is...if I want to add a fast hitch is it
just a matter of finding the parts and adding on? Or are the housings going to have to be
swapped?
Also will I need any extra hydraulic valving to use the remotes I will not be using for the hitch?
Thanks, Pete
You will need a ton of parts. Hitch uses separate hydraulic pump mounted piggy back on main pump. The lines to draft control valve inside rear top housing along with all draft control components, rockshaft etc. I believe you can use your housing but it would be simpler and easier to get the entire housing. Not even looking at the lower hitch parts themself.
If you are going to add a hitch mount a three point,both of mine have three point.(the book dosen t even show a fast hitch but they had them)
