Super M Crank pulley
Ok , started tearing down my wintwer project, a 1953 super M. Just wondering how the crank pulley comes off. Looks like a HUGE nut is bart of the pulley? About 2 and 3/4 inch socket? Looks like i see screw threads under the nut? How does THAT come off? Regular thread, or reverse? I'm thinking I should get that off before i pull the engine, so i can put it in gear and lock up the motor. I'll be pulling the front bolster to get at it. Any advice, input or ideas guys? Anyone?... Thanks Darryl
Darryl - That big crank pulley nut is regular, right-hand threaded with a 2-1/2" hex. I found 2-1/2" stamped steel wheel bearing socket worked nicely.
On my '53 SM the nut came loose with little effort - a couple good tugs on a breaker bar against engine compression had the nut turning.
Once the nut is off the pulley simply slides off the crank. Mine came off easily by hand - no puller required.
On the other end of the spectrum, LOL, my pulley took my dad and I each working a die bar with a 4 foot cheater pipe to pry my pulley off my SMD. I was really afraid we were going to break something. Some people have to use a puller.
Dan
Had to laugh at how different those relies were. Iif it were mine I've found that lots of heat and lots of PB Blaste works, plus patience. Do the heat/PB for a few days, it helps t get iin there and loosen up things.
Great tip about the wheel bearing socket. I doubt if I will be so lucky to have the pulley just slide of though. Heres hoping!!
I agree! Most of the time you have to use the PB Blaster and the big torch, several times, over a few days to bust some of this old stuff loose. I've seen where other guys also use a bearing seperator behind it to pull it off. Might have to buy some new tools. Part of the fun , right?
