pto support on 300u
deene
my uncle has a 300u that he needs the part that bolts on with the bearing and seal for the pto shaft..what all models will fit this tractor?..any advice appreciated..thanks in advance
If it's the output shaft seal and housing. If seal housing mounts with 2 bolts, found on most H and M tractors and a few others. If three bolts the planetary PTO like SMTA, 300, 350, 400, 450 some 460 and 560 and some others.
