Super H platform
Ken M
Is the foot rest/platform the same on the H as the SH? Mine is badly eaten up from the battery under the seat. I would think one for an H would be easy to find.
I'm guessing if yours is eaten up from battery acid then you probably have a stage 2 Super H with the live hydraulic pump? If so then I would doubt the covers are the same due to needing different mounting points for the different seat. Sam
The mount points likely have a casting bulge reinforcement under each bolt hole where the battery/seat system bolts on. Drilling an H plate will find oil. Jim
Will work if you stay away from early H ones with slot and 2 seat mounting holes. One with 4 holes for seat mounting would be late enough I think. At least two shift forks had later numbers on them but think the lower numbers will work if on a cover with 4 seat mount holes on up. If not the same you may need to install the SH shift forks to cover. Compared them before and think they were the same dimensions but memory fools me sometimes. Battery box uses two of the previous type seat mounting holes for bolts inside the box.
