Looking for a hydraulic manual for a 404 IH tractor
Looking to buy a good shop manual for a IH 404 1963 tractor. I am trouble shoot a slow hydraulic problem. The manual on this web site doesn’t state if it cover the hydraulic system. Does anyone know if it does or have a suggestion for a good shop manual the cover the hydraulics?
Bought a hydraulic manual from ?Binder?, great book, solved both of my problems. Took hydraulics apart that are under the seat, found no broken spring or bad o-rings. Reassembled and first problem was gone, which was, it was not coming off of high pressure. Linkage was not adjusted properly. Second problem was the system was very slow. Found out the by-pass valve in the filter canister was in wrong. Hydraulics works great now.
Thanks guys for the suggestion.
