hoosierhog
I have 2 questions.
1). I have 2 oliver discs modle 242. one has 9 blades per gang and measures 11.5ft across and also has single wheels. the other disc is the same model but has 10 blades her gang and measures 12.5 ft across the back. it has tandem wheels. both discs need work i like the bigger one but the smaller one needs less work. I have a 67 farmall 656 gas in good condition. which one would be the better choice.
2) I like my 3-16 3 point plow but I have acquired an oliver 5 bottom 16in plow. the last bottom could be removed. a lot of guys keep telling me to make it a 4 bottom pull it with my 656. that seems like way to much plow for a 656 but i have never tried anything bigger than a 3-16. I don't want to put the work in on the plow to make it field ready if i can't use it. I just as soon sell it to some one who can use it and let them do the work. so can a 656 pull a semi mount 4-16?
thank you
thank you
