drmmartin64
I am working on a 2424 international with a 2000 loader. a new front hydraulic pump has been installed by me. I drained the hydraulic fluid from the reservoir and transmission. the reservoir fluid was a light green and transmission a slight darker. rear end fluid was darker. trans had water in it. my question is how to remove and flush the left over fluid in reservoir and trans. will be changing the small suction filter. have large 24 inch suction filter also mounted in frame. I believe the bad pump was causing air in lines and at that time the fluid was a milky color. any advice is greatly appreciated.
